If you use Ajax under Umbraco Macro User Control, you will get the above javascript error.
The solution is to add the ScriptManager as follows:
<ajaxToolkit:ToolkitScriptManager runat="server" ID="ajaxScriptManager" EnablePartialRendering="true" CombineScripts="false" />
Reference:
http://www.bloodforge.com/post/AjaxControlToolkit-is-undefined-(javascript).aspx
'AjaxControlToolkit' is undefined javascript error.
Reference:
