  • Tom Maton 387 posts 660 karma points
    May 05, 2010 @ 11:43
    Tom Maton
    Adding my own icons to Umbraco for Document and Media types
    Hi All,
    Basically my question is as mentioned above.
    How do I reference my own icons to Umbraco for Document and Media types?
    I've copied them to the relevant folders but I can select the icon onlt the new thumbnail image.
    Tom
    May 05, 2010 @ 11:54
    Lee Kelleher
    2
    Hi Tom,
    You've probably already done this, but just in case...
    The thumbnail images are found in: \umbraco\images\thumbnails\  and the icon images are in: \umbraco\images\umbraco\
    Once you've added new thumbnail/icon images, they should appear in the Document/Media Type edit screen dropdowns.
    If you want to change the icon on a node-basis, then take a look at the Icon Picker package:
    http://our.umbraco.org/projects/icon-picker
    Cheers, Lee.
    May 05, 2010 @ 11:55
    Kim Andersen
    2
    Tom, you should be able to use your own icons for document types, if you have put them in the correct folder: /umbraco/images/umbraco
    If you have already put your images here, try refreshing the page, to see if the new icons will appear in the drop-downlist under the document types. You shouldn't need to reference the images anywhere.
    This should work, as I have done this plenty of times.
    /Kim A
    May 05, 2010 @ 12:03
    Tom Maton
    Cheers guys,
    Help much appreciated, I can now seen them but now they show (deprecated) next to them in the drop down, any idea how to remove this?
    Tom
  • Hendy Racher 863 posts 3849 karma points MVP 2x admin c-trib
    May 05, 2010 @ 12:12
    Hendy Racher
    I've always ignored the depreciated label... (one of the first things I usually do is install the FamFamFam icons package), perhaps it's just an indication that the UI is to change from a DropDownList, or to use css sprites instead of individual images ?
