  • Morten Nielsen 3 posts 23 karma points
    May 05, 2010 @ 11:48
    Morten Nielsen
    Simple GetMedia problem
    This works:
    <xsl:variable name="media" select="umbraco.library:GetMedia(1070, 0)/data"/>
    This doesn't:
    xsl:variable name="media" select="umbraco.library:GetMedia($currentPage/data [@alias = 'PageImage'], 0)/data [@alias = 'umbracoFile']" />
    When saving Xslt file, I get this:
    (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime, XPathNavigator {urn:schemas-microsoft-com:xslt-debug}current)
    at Root(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter writer, Boolean closeWriter)
    at System.Xml.Xsl.XmlILCommand.Execute(IXPathNavigable contextDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter results)
    at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, TextWriter results)
    at umbraco.presentation.webservices.codeEditorSave.SaveXslt(String fileName, String oldName, String fileContents, Boolean ignoreDebugging)
    My mediapicker field has @alias='PageImage', and I have done this quite many times before.
    Can anybody kick my brain, just a bit.
    May 05, 2010 @ 11:52
    Kim Andersen
    HI Morten
    Try putting a <xsl:if> around your code like this:
    <xsl:if test="$currentPage/data [@alias = 'PageImage'] != ''">
    <xsl:variable name="media" select="umbraco.library:GetMedia($currentPage/data [@alias = 'PageImage'], 0)/data [@alias = 'umbracoFile']" />
    </xsl:if>
    This makes sure that the PageImage-field is not empty.
    Otherwise you could also check the "Skip testing"-box at the top of the editor, and see if the code fails, or still works.
    /Kim A
    May 05, 2010 @ 12:00
    Morten Nielsen
    Good point, it compiled now.. Thanks alot
    I didn't  expect the compiler to look for data. I mean the Xslt File, doesn't which file it is been rendered in?!
    Now I'm left wondering why there is no data in the field, when the media picker is filled, the image is OK, and all is published?
    guess I'm rusty.
    May 05, 2010 @ 12:02
    Morten Nielsen
    OK sorry, forget the last comment, I works now. I just don't know why :)
