  • Michael Stanley 7 posts 27 karma points
    May 05, 2010 @ 14:38
    Michael Stanley
    How do I get sibling nodes?
    I have a content tree that looks like this:
    <Content>
        <NodeA>
            <NodeA1/>
            <NodeA2/>
            <NodeA3/>
        </NodeA>
        <NodeB>
            <NodeB1/>
            <NodeB2/>
        </NodeB>
    </Content>
    I am trying to use the nodeFactory to navigate this tree. If my current node is NodeA2 and I want to get to NodeB2, I thought I could do something like this:
    Node root = Node.GetCurrent();
    while(root.Parent != null)
        root = root.Parent;
    Node NodeB2 = root.Children[1].Children[1];
    However, the loop to get the root node stops at NodeA because the parent of NodeA is null. How am I supposed to get to the sibling nodes?
    May 05, 2010 @ 14:51
    Michael Stanley
    It looks like this:
    Node root = new Node(-1);
    will get the Content node and NodeA and NodeB are both children. A little weird since all the nodes are children of the Content node but the Content node is not a parent of its children???
  • Chris Dunn 210 posts 401 karma points
    May 05, 2010 @ 17:01
    Chris Dunn
    Just my thoughts.  The root node is not a traditional node.  If you check the database the parent of the root node is also -1, the root node.  And in the data/umbraco.config it is specified as <root> vs <node>.  So since it's not a traditional node, it functions a little bit differently.
    -Chris
