  • Dotnet Developer 7 posts 27 karma points
    May 07, 2010 @ 06:51
    Dotnet Developer
    Contents do not appear
    I have started creating my pages with Umbraco but the text written in the content field deos not get visible when I Preview the page. I have saved and published the page but nothing is going to work.
  • Tom Maton 387 posts 660 karma points
    May 07, 2010 @ 09:38
    Tom Maton
    Are you calling the content section on your template?
    eg.
    <umbraco:Item ID="Content1" runat="server" Field="bodyText" />
    Change your field to the name you have called it within Umbraco
    Tom
    May 07, 2010 @ 09:45
    Dotnet Developer
    Thanks a lot you have solved my big problem. It worked for me.
