Ok So I know this has to be an easy one. The layout of all my pages is going to be the same (vertical nav on the left, content on the right, with a horizontal nav on top). I have the masterpage setup for the horizontal nav, but I am unsure about setting it up for the vertical nav on the left hand side. Here is the kicker..... The vertical nav on the left changes depending on what page you are on. I know I could code it in the viewer, but is there a nice and easy way for NON-IT related people to do it. I assume you can create a "side navigation" content area that can be added in a WYSIWUG interface. Can someone tell me or point me in the right direction. A good example would be www.qbe.com (go from page to page). Thanks.
Its a project which is easy installed into umbraco and works a treat and is fully customisable for levels etc. I Have used it on a few projects and works everytime.
Is there a reason why you are wanting to change the vertical nav manually instead of having it generated automatically?
To make it dynamic: You can save a lot of time and trouble buy using "List Sub Pages From Current Page." It one of the provided XSLT templates. A little bit of tweaking and you have a nav that is similar to the site you provided.
To change it manually: You should be able to get away with using the Related Links datatype that is provided with Umbraco.
Just go to the Developer, right click on " XSLT Files" and click "Create," name it SubNav (or something similar), under "Choose a template" select "List Sub Pages From Current Page" and then click create. This will give you all of the code to make it work. Just drop the macro (that it created automatically for you) into your template.
Creating Vertical Side Navigation Bar
Take a look here http://our.umbraco.org/projects/cogworks---flexible-navigation
Tom
To make it dynamic:
Hope this helps.
Donald
Donald,
Can you point me to a tutorial on List Sup Pages from Current Page, or an example. Thanks.
Isaac,
Donald
Here's another one,which open's and close the sub-levels without postback
It can be seen here www.vgc.dk
<!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]>
<xsl:stylesheet
version="1.0"
xmlns:myFuncs="urn:my-scripts"
<xsl:param name="startLevel" select="2"/>
<msxml:script implements-prefix="myFuncs" language="JavaScript">
<![CDATA[
var myArray = new Array();
function GetCount(){
return myArray.length-1;
function Incr(){
myArray.push(0);
</msxml:script>
<xsl:variable name="openPosition">
<xsl:for-each select="$currentPage/ancestor-or-self::node[@level = 2]/node[string(./data [@alias='umbracoNaviHide']) != '1']">
<xsl:if test="count(current()/node[string(./data [@alias='umbracoNaviHide']) != '1']) > 0">
<xsl:value-of select="myFuncs:Incr()"/>
<xsl:for-each select="current()/node[string(./data [@alias='umbracoNaviHide']) != '1']">
<xsl:if test="$currentPage/@id = @id">
<xsl:value-of select="myFuncs:GetCount()"/>
</xsl:if>
</xsl:for-each>
</xsl:if>
</xsl:for-each>
</xsl:variable>
<xsl:template match="/">
<xsl:if test="count($currentPage/ancestor-or-self::node [@level = 2]/node[string(./data [@alias='umbracoNaviHide']) != '1']) > 0">
<ul id="SubNavi" class="SubNavi">
<li>
<a>
<xsl:attribute name="href">
<xsl:choose>
<xsl:when test="@nodeTypeAlias='PlaceHolder'">
<xsl:value-of select="'#'"/>
</xsl:when>
<xsl:when test="@nodeTypeAlias='URL'">
<xsl:value-of select="./data [@alias='url']"/>
</xsl:when>
<xsl:otherwise>
<xsl:value-of select="umbraco.library:NiceUrl(@id)"/>
</xsl:otherwise>
</xsl:choose>
</xsl:attribute>
<xsl:if test="@nodeTypeAlias='URL' and string(data [@alias='target']) !=''">
<xsl:attribute name="target">
<xsl:value-of select="./data [@alias='target']"/>
</xsl:attribute>
</xsl:if>
</a>
<ul>
<li>
</a>
</li>
</xsl:for-each>
</ul>
</xsl:if>
</li>
</xsl:for-each>
</ul>
</xsl:if>
function initMenu() {
$('#SubNavi ul').hide();
<xsl:if test="string($openPosition) != ''">
$('#SubNavi ul:nth(<xsl:value-of select="$openPosition"/>)').show();
</xsl:if>
$('#SubNavi li a').click(
function() {
var checkElement = $(this).next();
if((checkElement.is('ul')) <xsl:text disable-output-escaping="yes">&&</xsl:text> (checkElement.is(':visible'))) {
return false;
if((checkElement.is('ul')) <xsl:text disable-output-escaping="yes">&&</xsl:text> (!checkElement.is(':visible'))) {
$('#SubNavi ul:visible').slideUp('normal');
checkElement.slideDown('normal');
return false;
$(document).ready(function() {initMenu();});
</script>
</xsl:template>
</xsl:stylesheet>
/Paul S
Tom,
I have a question about about the flexible navigation. How do you set up CSS for it? I am having the darndest of times. Thanks.
