  • Dotnet Developer 7 posts 27 karma points
    May 08, 2010 @ 07:53
    Dotnet Developer
    Macro
    I want to create the parameter in macro with "Type= contentCurrent", but I can't see "contentCurrent" in "Type" dropdown. What can I do for it?
    May 08, 2010 @ 09:06
    if you need to add a parameter for your macro you should add it in the "developer" section under the "Macro" folder. Select the macro you want to add the parameter to and select the "parameter" tab. Now you can add your parameter.
    May 08, 2010 @ 11:23
    Dotnet Developer
    Thanks for your reply. But where and how I can call it?
