  • Jeffrey Schoemaker 408 posts 2138 karma points MVP 9x c-trib
    May 10, 2010 @ 11:25
    Jeffrey Schoemaker
    Exclude pages from a domain for another domain in multi lingual websites
    I made a site in Umbraco after watching the movies about "Running Multiple sites". I copied my site (with the language "Dutch" assinged to it) and made an english version. Both sites I assigned a different hostname (dutch.mywebsite.com and english.mywebsite.com)
    I have the following site structure
    * Home (domain dutch.mywebsite.com)
    ** Artikel 1 (artikel_1.aspx)
    ** Contact  (contact.aspx)
    * Home (domain english.mywebsite.com)
    ** Article 1 (article_1.aspx)
    If I browse to dutch.mywebsite.com/artikel_1.aspx it shows the right page. But the problem is that I can also go to dutch.mywebsite.com/article1_aspx, which shows a article of the other domain, although the article_1.aspx is not in the tree of dutch.mywebsite.com.
    Is there a way to prevent this from happening without making a 301-redirect for every page?
    May 10, 2010 @ 12:07
    Dirk De Grave
    Jeffrey,
    Did you change the useDomainPrefixes option to true in config/umbracoSettings.config
     <useDomainPrefixes>true</useDomainPrefixes>
    Hope this helps.
    Regards,
    /Dirk
    May 10, 2010 @ 12:15
    Jeffrey Schoemaker
    Thanks, Dirk. Sometimes life's so easy :)
