  • Sachin 19 posts 49 karma points
    May 10, 2010 @ 14:50
    Sachin
    Hiding some fields in member properties
    How can I hide some fields from the members edit page, i.e. if I want to hide name and email from the properties tab of members section, how can I do it.
    Thanks in advance,
    Kind Regards,
    May 10, 2010 @ 15:06
    Dirk De Grave
    Don't think you can, I've seen a package making it possible to hide some properties on a document, not sure if that'll work in the member section
    /Dirk
    May 10, 2010 @ 15:11
    Sachin
    Hi Dirk,
    Thanks for your prompt response. What I meant by disable is that when admin checks members property, he / she should not see that particular field in admin, i.e. by default admin can see name, created by created and so on but I don't want admin to see name field from it.
    Thanks in advance,
    Kind Regards,
  • Bandico0t 11 posts 48 karma points
    Jan 16, 2014 @ 11:21
    Bandico0t
    Hi guys.
    Has anyone found solutions for this problem?
