  • AN 22 posts 42 karma points
    May 11, 2010 @ 08:49
    AN
    Problem placing umbraco:item within anchor title attribute in template
    In a template, I have an anchor tag eg. <a href="/" title="">Name</a>.
    When trying to place an umbraco:item within the title attribute, it's as if the templating engine does not catch the umbraco:item.
    I'm guessing it's something todo with placing umbraco:item's in enclosed <>..
    <a href="/" title="<umbraco:Item field="title" recursive="true" runat="server"></umbraco:Item>"><umbraco:Item field="title" recursive="true" runat="server"></umbraco:Item></a>
    Which in turn outputs
    <a href="/" title="&quot;&lt;umbraco:Item" field="title" recursive="true"></umbraco:Item>">Entered value</a>
    Help? :o)
  • Tobias Neugebauer 52 posts 93 karma points
    May 11, 2010 @ 10:13
    Tobias Neugebauer
    Hello Andreas,
    I've tried your code with a smal change: i used single quotes instead of double quotes for the title attribute. This code worked for me:
    <a href="/" title='<umbraco:Item field="title" recursive="true"
    runat="server"></umbraco:Item>'><umbraco:Item
    I hope this does work for you also
    Toby
    May 18, 2010 @ 13:50
    AN
    Hi Toby,
    Thanks, I've changed the code.
    However, I'd still like to know what was/is causing the problem..
    :o)
    May 18, 2010 @ 14:05
    Hi Andreas
    I think the answer is implicitly in the post with the solution. It's probably because you used double quotes instead of single quotes, which has probably killed the parsing of the code since you are using double quotes in your HTML maybe.
    May 18, 2010 @ 14:52
    AN
    Alright.. Would that be considered a bug, the Umbraco crew should be notified of, or is it ligitimate enough, that the parsing breaks when using double quotes in my situation?
  • Douglas Robar 3570 posts 4711 karma points MVP ∞ admin c-trib
    May 18, 2010 @ 17:06
    Douglas Robar
    2
    It isn't a bug per se, but a requirement of every programming language I'm familiar with... you must distinguish levels of quotes to avoid confusion.
    In your case, you've already opened a single quote for the title= parameter and need to use the other kind of quote marks for the fields in the umbraco:item tag to avoid confusion about where the title= parameter ends.
    For what it's worth, it is also the case in "spoken" languages as well...
    You wouldn't write... He said, "it is also the case in "spoken" languages" as well"
    Rather, it would be written either as: He said, "it is also the case in 'spoken' languages as well"
    or as: He said, 'it is also the case in "spoken" languages as well'.
    Hope that helps clear up what's going on and why.
    cheers,
    doug.
    May 25, 2010 @ 18:16
    AN
    Hi Doug,
    Thanks!
