  • Nick 4 posts 24 karma points
    May 12, 2010 @ 14:02
    Nick
    Post in the past?
    Is it possible to make a post in the past?
    When I specify a past date it simply uses todays date and places my entry at the top of the list, but I would like to place them at the bottom as they should have been posted months ago.
    Thanks in advance!
  • Stefan Kip 1614 posts 4131 karma points c-trib
    May 12, 2010 @ 14:35
    Stefan Kip
    Could you elaborate a bit more? What are you trying to accomplish?
    May 12, 2010 @ 15:05
    Nick
    Sorry, sure.
    I am posting a new news article. I would like this article to be posted with a date which is in the past and be placed before my latest articles (so it appears to be an old article). However when I specify the old date it is simply posting the article using todays date and placing it at the top of the article list.
    Hope this makes sense!
  • Chris Dunn 210 posts 401 karma points
    May 12, 2010 @ 15:21
    Chris Dunn
    Check you're xslt to see the order the it's being sorted on.  This directly after you're for-each loop first statement.  Make sure it's being sorted on @updateDate or whichever date you would like to sort on.  Are you using Publish At date or a custom newsDate?
    <xsl:sort select="@updateDate" order="descending"/>
    or
    <xsl:sort select="./data [@alias='newsDate']" order="descending"/>
    -Chris
    May 12, 2010 @ 15:28
    Nick
    Sorry Chris im not a developer, just a user publishing posts via the front end system
    May 12, 2010 @ 15:35
    Chris Dunn
    Are you using a package like blog 4 umbraco or cws for your posts?  Or is this a custom implementation?
    -Chris
    May 12, 2010 @ 17:39
    Stefan Kip
    Nick,
    For many websites I've developed, I used my own News implementation, which has a property called 'Past Date'.
    With this property the customer is able to select a data in the past (for instance when transfering news from the old site to the new one). You should ask a developer to do something like this for you...
    Then the developer should implement this extra property in the output (like XSLT or .NET).
    May 12, 2010 @ 17:50
    Nick
    Thanks for your help, I will pass this on!
