  • tarekahf 215 posts 153 karma points
    May 12, 2010 @ 16:25
    tarekahf
    Un-document feature for multi-website deployment under Single Umbraco Installation.
    I was deploying my first Clinic Web Application and I was planning to have Multi-Website Deployment under a Single Umbraco Installation, so that I can add future web applications under the same setup.
    By chance, I found an undocument feature in Umbraco for Login.
    Follow there steps to have one Master Login Page for your Multi-Website Deployment under Single Umbraco Installation:
    1. Create a Login master page named "Login" in Back-Office (it will show as "Login.master"). Desing this Login Master Page so that it is common to all websites under this common Single Umbraco Installation.
    2. Create the code-behind "Login.master.vb" in VS in same folder as "Login.master". You can use this code-behined to add more control. For example, you can change the Parent Master Page depending on the current Root Website.
    3. Create a "Login" Document (Login.aspx page) using Back-Office, anywhere in the Content Tree, which is based on "Login" master page.
    4. Used the same default <authentication...> settings in web.config.
    Now, any time authentication is required, this "Login.aspx" page will be invoked, even if the page url/path is incorrect.
    I confirmed the above is working as mentioend, under Umbraco 4.0 and 4.0.2.
    I am not sure if this is a good thing or not.
    Tarek.
    May 13, 2010 @ 13:08
    Sebastiaan Janssen
    Actually, this seems to be expected behaviour. Any template that you create is approachable with just the template name, so if you create a template called "Search", you could go to site.ext/search.aspx and get the search template. Not sure what the "currentPage" variable will say, but it's probably going to be the homepage.
    In short, I don't see any problem here.
