I think you are running a few topics on the same subject. Comments are stored in the Comments table. I believe they made an update to the package which previously stored the comments as nodes which is what Sebastiaan is mentioning. I guess it depends what version you are running.
Yes, Chris, in that case I posted two topics, because I didn't now which category is the right one. I will try install the latest version and see what happens. Right now I don't see comment at all. Only on webpage, so I have 0 modification options. THX for your help,guys
I reinstalled the Blog package (2.0.26),but I still can't see the comment under the blog post in the Content. Chris,you are talking about Comments table.Where can I find it?
The comments table is in the Umbraco database. "dbo.Comments". If you setup the dashboard item for comments moderation, which is included with the package, you should be able to see the comments without looking directly in the database. If you're still having trouble, open sql express management studio to make sure the comments are actually being saved, and that the table exists.
You would setup the same way you would for other dashboard items, using the /config/dashboard.config. If you're new to the dashboard, you can use the same concept for other dashboard items in other packages or your own.
I did check the /config/dashboard.config and there is already the "comments" part and in the usercontrols there is CommentModeration.ascx file.So, why I still can't see the comments? Is there a special way to activate that? Where should I see a comment tag? If I click on the blog post in "Content", I should see the comments tag in the right, just next to the "content, options, properties" tags?
blog comments ... where are they????
I must be blind!!! Can someone tell me where can I delete blog comments? THX.
Uros
Blog comments are usually stored under each blog post. So if you go into the nodetree, fold open the blog post and you should see the comments.
Uros,
-Chris
Uros,
-Chris
Hi Chris,
THX for helping me. Here' I go with a stupid question.How do I setup the dashboard for comments?
http://umbraco.org/blog/2009/12/10/blog-4-umbraco-2010-–-comment-moderation. This was written for BFU 2.0.10 by Tim so it should work for you.
-Chris
THX for your patience.
Hi, Chris. I did play with dashboard.config and I did it. :). Thank you so much for your help.BEst regards!!!!
:) Good luck with your umbraco site, glad to help.
