  • Eric 27 posts 49 karma points
    May 13, 2010 @ 20:05
    Eric
    Error Copying Content Nodes when Relate copied items to original is checked.
    Whenever I try to copy a content node and I have the Relate copied ites to original checked, I get an object reference error.
    I am using umbraco v 4.0.3 (Assembly version: 1.0.3625.27276)
    May 13, 2010 @ 20:28
    Sebastiaan Janssen
    Could you provide a little more information, like the full exception that you're getting?
    May 13, 2010 @ 21:02
    Eric
    I notice when I select the Content Node, it displays: " [] has been selected as the root of your new content, click 'ok' below. " in the green box.
    Anyway here is the full exception:
    Source Error:
    Stack Trace:
    umbraco.cms.businesslogic.relation.Relation.MakeNew(Int32 ParentId, Int32 ChildId, RelationType RelType, String Comment) +305
    umbraco.cms.businesslogic.web.Document.Copy(Int32 CopyTo, User u, Boolean RelateToOrignal) +397
    umbraco.dialogs.moveOrCopy.HandleDocumentMoveOrCopy() +1631
    System.Web.UI.WebControls.Button.OnClick(EventArgs e) +114
    System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +139
    System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +28
    System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2980
    Version Information: Microsoft .NET Framework Version:2.0.50727.3603; ASP.NET Version:2.0.50727.3082
  • javier 59 posts 79 karma points
    Jul 14, 2010 @ 10:55
    javier
    Hi.
    I have this exact problem. It only happens when "Relate copied items to original" is checked. If not, it works fine.
    Any help with this?
    Javier
