Not sure this is the right place in the forum, but at least it's related to my users’ ui :-)
I admin a site which over time has gotten more information and menu items making it rather chaotic, so I wanna restructure and add another hierarchal layer and use mega-menus for better overview.
The problem is that some of the existing nodes will have to appear in two of the mega-menus, so i'm unsure of how to do this the best way regarding 'a natural sitemap', SEO and not having to update the same node two different places. Anyone have had this problem before or some thoughts on how to solve this best possible?
Hope it ain't all gibberish :-) Thanks in advance.
Well in Umbraco, I would create a property on the my document type that takes advantage of one of the redirect properties. You could make the redirect property of the type content picker, that way, if it's filled then you would be redirected to the actual page that holds the content.
However, this does require manual work, not exactly something you'd want to explain to your editors. I do believe that there are very few legitimate reasons for wanting to do this. In my opinion, a path to a page should be the only path to that page. As you've already mentioned, SEO-wise this is also not a great idea, it will look like duplicate content to spiders.
Thanks for your response and the useful link to your blogpost. Fortunately i'm also the editor, so no problem in that department. Like you point out (I very much agree) there are very few legitimate reasons for wanting to do this, but unfortunately I can't find a better solution for this particualar problem...
Multiply instances of childnodes
Hi Sebastiaan,
