Hi, I've seem to have i pretty anoying problem. And I got it in both dev and production enviroment. When trying to Insert Picture using the Rich Text Editor (umbraco v 4.0.3 (Assembly version: 1.0.3680.15881)) I get a Server Error:
Invalid attempt to read when no data is present.
Exception Details: System.InvalidOperationException: Invalid attempt to read when no data is present.
Source Error:
Stack Trace:
[InvalidOperationException: Invalid attempt to read when no data is present.]
System.Data.SqlClient.SqlDataReader.ReadColumn(Int32 i, Boolean setTimeout) +778859
System.Data.SqlClient.SqlDataReader.GetGuid(Int32 i) +29
umbraco.DataLayer.RecordsReaderAdapter`1.GetGuid(String fieldName) in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\datalayer\RecordsReaderAdapter.cs:263
umbraco.cms.businesslogic.datatype.DefaultData.get_Version() in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\cms\businesslogic\datatype\DefaultData.cs:157
umbraco.editorControls.uploadField.Save() in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\components\editorControls\uploadfield\uploadField.cs:101
umbraco.dialogs.uploadImage.Page_Load(Object sender, EventArgs e) in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\presentation\umbraco\dialogs\uploadImage.aspx.cs:56
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
System.Web.UI.Control.OnLoad(EventArgs e) +99
umbraco.BasePages.BasePage.OnLoad(EventArgs e) in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\businesslogic\BasePages\BasePage.cs:287
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Sorry. Can't seem to fix this. Still get the same errormessage.
But have figure out that the Save-method actually saving the name and GUID in the DB, put no files in the Media-folder. (And yes, the asp-net machine account have full rights).
can't save images
Source Error:
Anyone else got this?
Sorry - got a glance at the DB.
It's been messed up with some identity-problems on some tables when moved.
I'll fix this.
Sorry for the nagging on the forum :)
(Any moderator can close this)
What user is configured as the application pool user? This user needs to have write rights to the media folder at least.
