I run a local VistaDB umbraco install and i'm almost falling asleep when waiting for _anything_ in the umbraco backoffice. In some other threads i can see that people complain about the speed of the VistaDB. But is it really that bad and is it the only problem regarding loadtimes?
umbraco/editContent.aspx?id=xxxx
Hi there
http://localhost:1266/umbraco/editContent.aspx?id=1119 take 6 seconds to load on a page with 30 lines of pure text and 1 small image.
I've never tried the convert-to-sql thing before, but is it what should be done?
Yeah, that's my experience with VistaDB it's just really slow. If you can, try SQL Express, it's much better.
hmm, well then i have something to do in the weekend ;-)
