  • Simone Chiaretta 135 posts 542 karma points c-trib
    May 20, 2010 @ 11:18
    Simone Chiaretta
    How does umbracoUrlAlias is supposed to work?
    I have created a multilingual site (for sake of simplicity I add just one node per site):
    Content
     - it
        -  Iscrizioni
     - en
        -  Register
    I'd like that the Iscrizioni node is retrieved with the following urls:
    /it/Iscrizioni
    /Iscrizioni
    /it/Register
    The first is the correct one for SEO, and the one that will be used as link in the site
    The second is to preserve old urls of when the site was "mono-lingual"
    The third to allow url hackabolity (i.e. I go to /en/Register, I want to try if there an Italian version, I just change en to it)
    I added in the DocumentType a textstring property with the alias umbracoUrlAlias, and I set it to Iscrizioni,en/Register, but when I try to go to /Iscrizioni.aspx and to the /en/Register.aspx I get the 404 page.
    Any idea of what I am doing wrong?
    May 20, 2010 @ 11:21
    Simone Chiaretta
    Sorry, I meant, I set it to "iscrizioni,it/register" and doesn't work when I go to /Iscrizioni.aspx and to the /it/Register.aspx
    Damn, no editing feature in this forum yet? :)
    May 20, 2010 @ 11:26
    Simone Chiaretta
    2
    Nevermind... fixed it :)
    May 20, 2010 @ 11:29
    Lee Kelleher
    Hi Simone,
    I found that umbracoUrlAlias only works on lowercase.  Try going to "/it/register.aspx", see if that works?  Not sure why "/iscrizioni.aspx" doesn't work, as far as I can tell you have entered it correctly.
    Alternatively, if you are doing this for SEO purposes, I'd suggest taking a look at the 301 URL Tracker package, as that sends out the appropriate redirect headers.
    http://our.umbraco.org/projects/301-url-tracker
    Cheers, Lee.
    May 20, 2010 @ 11:32
    Simone Chiaretta
    Thank you, I'll have a look at it
