  • Daniel 44 posts 187 karma points
    May 20, 2010 @ 12:00
    Daniel
    Using Google Font Directory with Umbraco
    As you probably heard Google released an awesome feature yesterday - Google Font Directory, http://googlecode.blogspot.com/2010/05/introducing-google-font-api-google-font.html.
    To be able to use this feature with Umbraco two things are needed:
    1. Usage of the Google fonts on the web frontend
    2. Usage of the Google fonts in the Umbraco WYSIWYG editor
    Part 1 is very simple:
    1. Go to your Master template (Settings -> Templates -> <Your template>) and add the following in the <head> section: <link href='http://fonts.googleapis.com/css?family=Yanone+Kaffeesatz' rel='stylesheet' type='text/css'> (for other fonts see: http://code.google.com/webfonts)
    2. Go to your Stylesheet (Settings -> Stylesheets -> <Your stylesheet>) and add the following to your body tag (or other element): font-family: 'Yanone Kaffeesatz', arial, serif;
    I have not yet been successful with part 2 unfortunately. I have tried adding the html from Part 1.1 above in the <head> section of the following files without succes:
    - \umbraco\masterpages\umbracoPage.aspx
    - \umbraco\umbraco.aspx
    In my opinion that should suffice, but apparently it doesn't. Could it have something to to with using special fonts in a <textarea> element? Any suggestions/solutions to this would be appricieted by the entire community, I guess.
    May 20, 2010 @ 12:08
    Sebastiaan Janssen
    You need to do quite a bit more than that though, like initialize some javascript. See: http://code.google.com/apis/webfonts/docs/webfont_loader.html
    May 20, 2010 @ 12:16
    Sebastiaan Janssen
    Sorry, ignore me, I'm wrong. :-)
    FYI none of the fonts  work for me in the Chrome dev build.
  • Trevor Loader 199 posts 256 karma points
    Aug 10, 2011 @ 03:19
    Trevor Loader
    Did you every figure this out?
    Cheers
    Trevor
