I am new to umbraco and xslt and I am having a problem with rendering the correct nodes to screen. My Content tree consists of:
Content
-Home
--Sub Node - Folder
---Archive Node - Folder -- node id=1379
----January - Folder
-------Page Node
-------Page Node
----February Node - Folder
-------Page Node
-------Page Node
What I require for each month to be rendered as the header and the page nodes as a drop down list (This has been set up using a jquery accordian).
The problem I am getting is that the January folder is being rendered twice and the 4 page nodes are rendered underneath each January heading. Its quite obvious I am missing the point somewhere with XSLT and XPATH. Could some one tell me where I am going wrong please. My XSLT file is:
Traversing nodes
Hi folks,
Content
-Home
--Sub Node - Folder
-------Page Node
-------Page Node
-------Page Node
-------Page Node
<xsl:variable name="startnode" select="umbraco.library:GetXmlNodeById(1379)"/>
<xsl:template match="/">
<div class="event-details">
<h1><xsl:value-of select="$currentPage/@nodeName"/></h1>
<div class="function-wrapper">
<xsl:for-each select="$startnode/node">
<h2 class="trigger"><a href="#"><xsl:value-of select="$startnode/node/@nodeName"/></a></h2>
<div class="toggle_container">
<div class="block">
<ul class="list">
<xsl:for-each select="$startnode/node/node">
<li>
<a href="{umbraco.library:NiceUrl(@id)}" title="">
<xsl:if test="node!='false'">
<xsl:attribute name="title"><xsl:value-of select="@nodeName" /></xsl:attribute>
</xsl:if>
<xsl:value-of select="@nodeName" /></a>
</li>
</xsl:for-each>
</ul>
</xsl:for-each>
</div><!--end function-wrapper-->
</div><!--end event-details-->
</xsl:template>
Thank you
sorry, wrong forum. I have moved this to the xslt forum
