  • Chandima Jayanath 12 posts 32 karma points
    May 20, 2010 @ 15:02
    Chandima Jayanath
    How to handle customized error messages
    Umbraco system doesn’t allowed  to show customized error messages. any suggestion please
    My environment is:
    Umbraco version: 4.0.3
    asp.net: 3.5
    Windows: Windows2003
    IIS: 6.0
    May 20, 2010 @ 15:03
    Sebastiaan Janssen
    What do you want to customize about which error messages?
    May 20, 2010 @ 15:12
    Chandima Jayanath
    As a example, if i need to select URL for external site, i select 'Link Type' as External URL, but accidently I select Internal URL value for it, i need to show error message like "Your URL value is incorrect...."
    Is this possible to do? Please clarify
    Thanks!
    May 20, 2010 @ 16:49
    Sebastiaan Janssen
    You could PROBABLY do it by updating the speechbubble from some code, but it's not something that is very easy and sometimes it is just impossible to update that speechbubble I think. I don't think It was really made with much customization in mind.
    May 21, 2010 @ 07:22
    Chandima Jayanath
    Thanks for the answer.... !
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    May 21, 2010 @ 08:30
    Richard Soeteman
    HI,
    I suggest you use a regular expression to validate the field. If that's not possible I would create a custom datatype based on a usercontrol (More info on the Nibble Blog) And use a validator in that usercontrol that shows the error message. When you use the spoeechbubble/event method the data is already saved before the message is shown.
    Richard
