  • Ranjith 11 posts 31 karma points
    May 21, 2010 @ 12:10
    Ranjith
    Half the Way along Umbraco4
    Hi to all,
    This is Ranjith.... Im half the way in learning Umbraco4....
    Now im clear on "Document Types" and "Templates"... Im also working on xslt currently......
    I need to make a register form and a log In form, make to work in my website.... How to do this??
    And I need to know how important is xslt,  in Umbraco4!!....
    Thanks in Advance.....
    Regards,
    Ranjith
    May 21, 2010 @ 12:23
    Dirk De Grave
    well, hmm, xslt is quite important, but can be completely ignored if you're used to building user controls :P. Depends on your xslt skills whether to decide what suits best for you, choice is competely up to you.
    If you need register/login forms, have a look at the standard asp.net login controls, as umbraco runs on asp.net, it should be a breeze to integrate those in your templates.
    Morten has written a short how to on his blog.
    /Dirk
