Umbraco version: 4.0.2.1 / AspNet-Version 2.0.50727 / IIS: 7.0I'm seeing a 3 - 6 second delay between "umbracoInit" and "request handler" which renders a poorly performing siteregisterIapplications + Adding application 'umbraco.presentation.nodeFactory.UmbracoSiteMapProviderAccessUpdate registerIapplications + Adding application 'MediaEventHandler.MediaEventHandler 0.00185470499742286 0.001855aspx.page Begin PreInit 0.234740658379766 0.232886umbracoInit handling request 0.243457129327889 0.008716request handler current url '/en/home.aspx' 2.95332654010496 2.709869I will appreciate any suggestions as to what I can look out (outside of switching hosts, that's nonnegotiable.) Thanks!
BTW, I could not make this post using MacOSX/Snow Leopard/WebKit. After clicking submit, I'd be returned to a blank "create new post" screen.
Hiya,
Is it just a vanilla install of Umbraco, or have you written and event handlers of your own or installed any of the extensions?
Not a vanilla install. I'm not sure how I can report on what functions have been overridden or extended?
I need help addressing poor performance
Hiya,
