  • Uros Sankovic 107 posts 134 karma points
    May 25, 2010 @ 21:34
    Uros Sankovic
    after uninstalling CWS2
    I just uninstalled CWS2 package. The problem is when I go to "Content", it's not showing on the right side the "default page" I've created. Instead it's showing tabs "Contact logs" and "Email to a friend", which were part of CWS2. And of course it's telling me about the error, since there are no ascx files.How can I change that so it will show the tags which are part of my "default page" (document type)?
    THX
    May 25, 2010 @ 21:43
    Dirk De Grave
    Check whether dashboard.config still has references to both "Contact logs" and "Email to a friend" tabs/user controls. If so, remove those entries, restart your app so the config gets re-read and those tabs/users controls should be gone.
    Hope this helps.
    Regards,
    /Dirk
    May 25, 2010 @ 21:54
    Uros Sankovic
    THX Dirk
