I just installed umbraco and during the installation process i choose a clean one (whithout runway). Everything appears to be working well, i can create macros, stylesheets, templates, etc but one i try to create a "Document Type" i get an error.
The related template is created and the document type appears on the tree, however one i select it this error appears on the right side of the screen:
Object reference not set to an instance of an object. Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.] umbraco.controls.ContentTypeControlNew.setupInfoPane() in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\presentation\umbraco\controls\ContentTypeControlNew.ascx.cs:105 umbraco.controls.ContentTypeControlNew.OnInit(EventArgs e) in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\presentation\umbraco\controls\ContentTypeControlNew.ascx.cs:782 System.Web.UI.Control.InitRecursive(Control namingContainer) +333 System.Web.UI.Control.InitRecursive(Control namingContainer) +210 System.Web.UI.Control.InitRecursive(Control namingContainer) +210 System.Web.UI.Control.InitRecursive(Control namingContainer) +210 System.Web.UI.Control.InitRecursive(Control namingContainer) +210 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +378
-------------------------------------------------------------------------------- Version Information: Microsoft .NET Framework Version:2.0.50727.4200; ASP.NET Version:2.0.50727.4016
Also, i have no idea where this "d:\TeamCity" folder is comming from.
Error creating document type - clean installation
Stack Trace:
I didn't change anything, just left for a coffee and now.. it's working. That's weird :-|
Just had a similar issue. recycled the app pool and it's back now.
