  • Petr Snobelt 923 posts 1535 karma points
    May 27, 2010 @ 22:38
    Petr Snobelt
    How to delete property using db?
    I add property (with RRC) to my DocumentType, but Timeout occured duuring save or change on DocumentType. I then repeat it and it looks ok in developer's section. But when I try edit content with this document YOSD occured.
    stack trace
    umbraco.controls.ContentControl.addControlNew(Property p, TabPage tp, String Caption) +54
    umbraco.controls.ContentControl..ctor(Content c, publishModes CanPublish, String Id) +780
    umbraco.cms.presentation.editContent.OnInit(EventArgs e) +368
    System.Web.UI.Control.InitRecursive(Control namingContainer) +333
    System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +378
    I then try remove this property, but without luck - another YOSD with this stack trace:
    umbraco.cms.businesslogic.propertytype.PropertyType.delete() +77
    umbraco.controls.ContentTypeControlNew.gpw_Delete(Object sender, EventArgs e) +52
    umbraco.controls.GenericProperties.GenericPropertyWrapper.GenericPropertyWrapper_Delete(Object sender, EventArgs e) +28
    System.EventHandler.Invoke(Object sender, EventArgs e) +0
    umbraco.controls.GenericProperties.GenericProperty.DeleteButton2_Click(Object sender, ImageClickEventArgs e) +28
    System.Web.UI.WebControls.ImageButton.OnClick(ImageClickEventArgs e) +108
    System.Web.UI.WebControls.ImageButton.RaisePostBackEvent(String eventArgument) +118
    System.Web.UI.WebControls.ImageButton.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10
    System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
    System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36
    System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1565
    Is it possible to delete this property in db?
    I know Id of property and Id of documenttype
    May 27, 2010 @ 22:56
    Petr Snobelt
    I find a row in cmsPropertyType and change it's Node id to 99999 and it helps.
    Oct 02, 2010 @ 06:55
    Petr Snobelt
    It looks like nobody else has same problem, but it occurred to me again.
    I figured out that timeout is caused by populatePropertyData on umbraco.cms.businesslogic.ContentType
    This function adding empty data to all versions :-o of your created content. If you try add property to frequently used datatype it end with sql timeout error.
    Solution is runing following sql (with bigger timeout)
    insert into cmsPropertyData (contentNodeId, versionId, propertyTypeId) select contentId, versionId, @propertyTypeId from cmsContent inner join cmsContentVersion on cmsContent.nodeId = cmsContentVersion.contentId where contentType = @contentTypeId
    I don't know all umbraco internals, but adding new property to old versions looks like wasting db space.
    Petr
    BTW:Adding Connect Timeout property to umbracoDbDSN don't help
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Oct 03, 2010 @ 07:43
    Richard Soeteman
    Hi Petr,
    Had the same issue a while back only didn't seen your post.I wrote a blogpost about this. I solved this by writing a usercontrol that loops through the content and deleted the property from the contenttype. I've created a CodePlex issue for this which is resolved now.
    Richard
