Is Umbraco suitable for what I am trying to achieve?
I need to create a web (or non-web) system where a user can create a template layout with tags and placeholders for elements. They could then add new pages to this template. My system would need to pick up any elements that have changed and create an XML of the tagged content. I was just wondering what would be the best CMS or any other software I could use to implement this?
You could certainly use umbraco to create a system such as you describe (it is extremely flexible). But based on what little you've explained so far I would look elsewhere for a tool that more nearly fits your requirements.
If you don't find an alternative then come back to us, explain in more details what you're trying to achieve, and we'll do our best to describe how you might achieve your goals with umbraco.
Hi, Hastings,
In any event, do let us know what you discover.
cheers,
doug.
