Hi guys
I have a question about the createUserWizard control in umbraco. I have used the control to set up a membership feature on a clients website.
It works perfectly, but I would like to be to edit the text in the form that is rendered...
The text that is displayed by default is "Sign Up for Your New Account"... But I would like to change it to "Sign up for newsletter"
Can any one please tell me how to do so?
// Mikkel Johansen
http://msdn.microsoft.com/en-us/library/system.web.ui.webcontrols.createuserwizardstep.title(v=VS.100).aspx
/Dirk
Hi Dirk
Great... It works!! Sometimes the solution to your problems are as simple as this...
Thank you for your reply :)
Kind regards
Mikkel
Edit text in CreateUserWizard Control
Hi guys
// Mikkel Johansen
/Dirk
Hi Dirk
Kind regards
Mikkel
