Uros
Hi Uros,
The code-behind (source-code) for the user-control will be compiled into a separate DLL (in the /bin folder).
If you need access to the source for the blog4umbraco package, then take a look on CodePlex.
http://blog4umbraco.codeplex.com/SourceControl/changeset/view/42029
Cheers, Lee.
Where is "frmBlogComment.ascx.cs" file?
I can't find "frmBlogComment.ascx.cs" file? It's from Umbraco Blog 4.
Uros
Hi Uros,
Cheers, Lee.
