  • Johnny Mogensen 10 posts 29 karma points
    Jun 04, 2010 @ 12:41
    Johnny Mogensen
    Syncronize structure in many languages
    I have tricky question, regarding structure. I have one site with many languages and need to paste one page into the structure on all languages in one stroke, in other words i need to have a master site, where I sync the structure into all languages.
    I need to keep the same structure syncronised in all languages, so when I add a page in a 'master' language, the page should be copied to all or some of the languages.
    Is this possible?
    Cheers Gothardt
  • atze187 160 posts 215 karma points
    Jun 04, 2010 @ 13:03
    atze187
    Haven't used it yet, but this sounds like the relations api could help you:
    http://blog.hendyracher.co.uk/umbraco-relation-api/
    André
  • Matt Brailsford 4125 posts 22224 karma points MVP 9x c-trib
    Jun 04, 2010 @ 13:32
    Matt Brailsford
    Andre is correct. You would want to use the relationship api in conjunction with some event handlers.
    Setup some even handlers to be notified when a new page is created/saved and check the parents related node in the other site to know where to create the copy.
    Checkout this link from Neils for a similar concept plus some code sample to get you started
    http://umbraco.org/blog/2009/3/25/microsoft-translator-and-umbraco
    Matt
    Jun 15, 2010 @ 12:09
    Johnny Mogensen
    Great links,
    Thank you both, it was exactly what I was looking for!
    Johnny
