  • psiho 101 posts 96 karma points
    Jun 15, 2010 @ 11:45
    psiho
    accessing pages of another domain through wrong domain
    we just publsihed one of our Umbraco projects live (v4.0.2.1). It is a corporate website on 3 langueges, each language on its own domain: www.mplus.hr, www.mplus.nl and www.mplus.net. Structure is like this:
    - www.mplus.net
    -- about-mplus.aspx
    - www.mplus.nl
    -- over-mplus.aspx
    - www.mplus.hr
    -- o-nama.aspx
    Problem is that we can access any page from any domain. I.e. any of those work:
    www.mplus.net/over-mplus.aspx (which gives us a mix of english template and dutch content)
    www.mplus.net/o-nama.aspx (which gives us a mix of english template and croatian content)
    This creates probelms with Google indexing site and duplicate content. is there any way to disable this behavior?
    Jun 15, 2010 @ 19:14
    Sebastiaan Janssen
    You should probably set "useDomainPrefixes" to true in your /config/umbracoSettings.config
    Jun 16, 2010 @ 11:28
    psiho
    Thx. I don't know how I forgot about this I was using it before.
  • Julius Bartkus 51 posts 76 karma points
    Jul 19, 2010 @ 08:04
    Julius Bartkus
    in 4.0.3 I was using useDomainPrefixes and it worked fine, but in 4.5 for some reason it does not generate unique domains anymore.
    Does anyone have the same issue?
