  • Sa 118 posts 152 karma points
    Jun 16, 2010 @ 12:32
    Sa
    plugin
    Hello All..
    i would like to create a TinyMCE Richtext Editor plugin..
    where to begin with?
  • atze187 160 posts 215 karma points
    Jun 16, 2010 @ 12:44
    atze187
    I guess you want to develop something for v3.x, so this should be your stating point:
    http://wiki.moxiecode.com/index.php/TinyMCE:Create_plugin/3.x
    André
    Jun 16, 2010 @ 13:19
    Sa
    i am using umbraco v4.0.4.1.. i have included settings in tinyMceConfig.Config..  what about "customConfig " in tinyMceConfig.Config
    Jun 16, 2010 @ 15:00
    atze187
    Do you want to use an existing plugin or develop a new one?
  • ask 28 posts 48 karma points
    Jun 16, 2010 @ 15:06
    ask
    i am developing a new one
    Jun 16, 2010 @ 15:15
    ask
    @atz187 i am developing a plugin..i refered this link http://our.umbraco.org/wiki/how-tos/enabling-the-'template'-plugin-for-tinymce .. but it is not showing up
    Jun 16, 2010 @ 15:31
    atze187
    Sorry, I have no clue on that. The original post from Sam was about creating a new plugin, not using an existing one.
    Jun 16, 2010 @ 16:09
    Sa
    yes atze187 ,i am creating a new plugin..
    Jun 16, 2010 @ 21:57
    atze187
    @Sam: so the link I posted in my first reply should give you a slight idea of what's basically needed...
    Jun 17, 2010 @ 15:52
    Sa
    hi atze187., thanks for your reply.
    i am using lastest umbraco version..
    i am trying to implement color picker with TinyMCE Rich text Editor..
    if you can help me out with this?
    Jun 18, 2010 @ 07:52
    Sa
    Hi..
    plugin shows up in old version (Richtext Editor (TinyMCE2)) but not in new version(TinyCME v3)..  i feel the plugin is not working in new version or am i wrong?
    Jun 18, 2010 @ 10:50
    atze187
    If you send me the source, I'll have a look.
    Jun 18, 2010 @ 10:51
    atze187
    Oh, e-mail is mk_II (at) gmx (dot) net.
    Jun 23, 2010 @ 14:39
    atze187
    Hi Sam,
    take a look at that, there are quite a few changes i already made, but i haven't got all the way.
    http://wiki.moxiecode.com/index.php/TinyMCE:Migration_guide
    Jul 16, 2010 @ 11:33
    Sa
    in TinyMCEconfig.config file,i have a node called "customConfig" .
    if anyone can guide me what it does? if i add a variable where will it get affected?
  • Shivani Rajput 27 posts 97 karma points
    Oct 05, 2023 @ 10:06
    Shivani Rajput
    Hello, I want to know how we can create a plugin in Umbraco version 11/11+, please provide some reference step wise.
