  • Uros Sankovic 107 posts 134 karma points
    Jun 18, 2010 @ 15:42
    Uros Sankovic
    How to work with Flash?
    as I understand, Umbraco saves all data in XML. If so, is it possible to prepare a DocumentType for Flash movie? Flash movie reads the XML, which gets data through DocumentType. Any ideas?
    THX for any help.
    Uros
    Jun 18, 2010 @ 15:51
    dandrayne
    Hi Uros
    Absolutely it is.  You can use xslt macros to create an xml feed suitable for flash.  Lots of sites do this, an example one we did at www.davidoni.com
    It would probably not be recommended to read the umbraco xml file directly.  By transforming it with xslt you are able to produce exactly the xml you want.
    Dan
    dandrayne
    oops, that was www.davidboni.com
    Jun 18, 2010 @ 15:53
    Uros Sankovic
    Dan, thx for your reply. Can you give me please more directions?I'm pretty new to XSLT. And how did you tell the Flash where to get the data?
    THX again.
    Jun 18, 2010 @ 15:57
    Rich Green
    If you have Umbraco TV then look here
    http://umbraco.org/documentation/videos/for-developers
    Under "Rich Internet Applications"
    Rich
    Jun 18, 2010 @ 16:06
    Uros Sankovic
    Rich, I don't have Umbraco TV
    Jun 18, 2010 @ 16:15
    dandrayne
    Hi Uros
    For xslt you can find some great resources in the umbraco Wiki and docs section (see http://umbraco.org/documentation/books/xslt-basics/ for a start).
    Once you've got a handle on that, here's how I output xml.
    1)  Create an xslt macro that gets site data and creates xml.  below is a very simple example
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
    version="1.0"
    <xsl:template match="/">
    <sitedata>
    <galleries>
    <xsl:for-each select="$currentPage/node [@nodeTypeAlias='Gallery']">
    <gallery>
    <name><xsl:value-of select="@nodeName" /></name>
    </gallery>
    </xsl:for-each>
    </galleries>
    </sitedata>
    </xsl:template>
    This creates output like the following
    <sitedata>
    <galleries>
    <gallery>
    <name>Gallery one</name>
    </gallery>
    <gallery>
    <name>Gallery two</name>
    </gallery>
    </galleries>
    </sitedata>
    Which can be used in your flash as xml.  To do that,
    2) create a template to hold your new xslt macro, such as
    <%@ Master Language="C#" MasterPageFile="/umbraco/masterpages/default.master" AutoEventWireup="true" %>
    <asp:Content ContentPlaceHolderID="ContentPlaceHolderDefault" runat="server">
    <umbraco:Macro Alias="yourMacroName" runat="server"></umbraco:Macro>
    </asp:Content>
    This sticks the xml declaration.  Now the simplest thing to get your template working is.... say your homepage is at /home.aspx - you can use this template on it at
    /home/templateName.aspx
    or
    home.aspx?altTemplate=templateName
    3) and to pass that to flash I just use flashvars.  For that see http://kb2.adobe.com/cps/164/tn_16417.html or (my recommended way) use swfobject and pass the flashvars in via javascript (http://code.google.com/p/swfobject/wiki/documentation).  Your swf file could allow a flashvar for "xml location" or if you want you could even hardcode it in the swf.
    Hope this helps,
    Dan
    Jun 18, 2010 @ 16:55
    Uros Sankovic
    Thank you very much!
    Uros
