    Jun 18, 2010 @ 22:37
    Tom Fulton
    TinyMCE - Images replaced with other images
    I'm having a strange problem where TinyMCE seems to be replacing images inserted into the WYSIWYG with other images.
    For example, I can insert an image from the Media library and see it in the WYSIWYG.  But when clicking Save or Save and Publish, the image is then replaced with a completely different image from the Media library.  It only happens on some images.  Also, each image that gets replaced is always replaced with the same one - ie yam11.jpg  is always replaced with newdvd51.jpg, father_04.gif is always replaced with 61_1.jpg, etc.
    Looking at the HTML code in TinyMCE,
    <p><img src="/media/1110/yam11.jpg" alt="yam11.jpg" title="yam11.jpg" width="800" height="600" rel="800,600" /></p> gets replaced with <p><img src="/media/1247/newdvd51.jpg" alt="yam11.jpg" width="800" height="600" rel="800,234" /></p>
    Oddly enough, I have encountered this same problem before on another Umbraco site.  Rather than troubleshoot I fixed by deleting the problem media folder and reuploading the images.  But in this case there are a lot of media folders/items and I'm not sure which one is causing the problem.
    Anyone ever seen this or have any ideas where to start looking?
    Umbraco 4.0.3 / .NET 3.5 Integrated / Windows 2008 / IIS7 / (IE and Firefox)
    Note - all the images (except for 2) were uploaded with Nibble's ZipUpload
    Tom
  • Dan 1288 posts 3942 karma points c-trib
    Jun 18, 2010 @ 23:34
    Dan
    Hi Tom,
    Sounds like the same issue raised on here a while back.  It's a bug with the zip-upload component: http://our.umbraco.org/forum/ourumb-dev-forum/bugs/6598-Wrong-images-in-the-rich-text-editor-when-saving-or-publishing.  I can't remember what the final outcome was, but zip-upload was definitely the culprit!
    Hope this helps...
