I'm trying to sort few pages in UI. I'm getting the sort dialog with message "Please wait. Items are being sorted, this can take a while. Do
not close this window during sorting". There is only 6 pages (all published), but the dialog never disappears. Any tips while sorting is not working ?
I'm asking you this since it could may be an unoticed bug in the 4.0.4.1 release perhaps (I'm not saying it is, but then others can see if they experience the same problem).
There was no pressure to fix it and I simply forgot about this problem :-). Checked my pages using the firebug and I think the issue might caused by missing js files, but I didn't try to fix it so far.
I'm using Umbraco 7.3 and cannot sort custom formats for the RTE editor via the Umbraco backend. (error below FYI)
However, if you simply re-order the style declarations in the stylesheet, the RTE will display them in the order it reads them, so its easy to get around this silly bug.
Hello admins and Umbraco devs - can you advise when will this be fixed...?
sorting doesn't work
Do not close this window during sorting". There is only 6 pages (all published), but the dialog never disappears. Any tips while sorting is not working ?
Dorota
Hi Dorota
What version of Umbraco are you using? And is it a clean installation without any kind of modification done to the Umbraco core?
I am using version 4. I didn't make any changes to umbraco core.
Is it 4.0.3 or 4.0.4.1?
umbraco v 4.0.2.1 (Assembly version: 1.0.3441.17657)
up
if you have firebug running, what does the firebug console is returning for the sorting ajax request ?
Did you ever get this problem resolved? I've just started getting this problem and wondered if you ever found a solution?
Rgds
Pete
Hi Pete,
Share please if you managed to find a solution.
Dorota
5 years later and this bug still persists.
* The error (output in chrome dev tools): *
