New I am relatively new to umbraco but have been playing around with it for a few weeks now. Suddenly today I noticed that my context menu is no longer working in the Content section. I am getting the regular windows menu instead. I am running version 4.0.4.1. I have not changed any config or folder permissions or settings so I am pretty baffled. Any help would be much appreciated.
I have had this issue earlier. What solved my problem, was to switch my logged in user language from "Danish" to "English". I had set the admin-language to danish, but this seemed to cause a problem. Later on in the same solution, the issue occoured again, and this time is was permission reasons. We had switched to a new server, so the permission settings wasn't totally right.
Try checking your permission settings in your file system to see if everithing is all right here. Hopefully this could solve your problem.
Thanks for your quick response, I figured out the problem and I am pretty sure its a bug. Neither of the issues you suggested were actually the problem, but then I remembered I had un-installed the courier package today. So I re-installed it and hey, my context menu was back! I un-installed and sure enough it was faulty again, so now I guess I have to have it permanently installed.
Problems with context menu in content section
Hi Everyone,
Hi Enitan
/Kim A
Hi Kim,
I cannot get the contect menu to work. Can anyone tell me what I'm doing wrong
First Error:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; GTB6.5; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; MDDC; .NET4.0C; .NET4.0E)
Timestamp: Thu, 15 Jul 2010 19:43:22 UTC
Message: Unterminated string constant
Line: 36
Char: 116
Code: 0
URI: http://127.0.0.1:8081/umbraco/js/contextmenu.aspx
Second Error
Timestamp: Thu, 15 Jul 2010 19:42:50 UTC
Message: Object expected
Line: 1
Char: 1
Code: 0
URI: http://127.0.0.1:8081/umbraco/TreeInit.aspx?app=developer
