Issue with media stored in Azure Blob Storage using umbraco 7.5.2+
I have an issue with media stored in Azure Blob Storage using umbraco 7.5.2
The old media content with images on the blob are unavailable to modify or delete, the image (file upload) and the custom media type instance itself. This is the error.
An error occured
The given key was not present in the dictionary.
Exception Details
System.Collections.Generic.KeyNotFoundException: The given key was not present in the dictionary.
Stacktrace
at System.Collections.Generic.Dictionary`2.get_Item(TKey key)
at Umbraco.Core.Persistence.Repositories.MediaRepository.PersistUpdatedItem(IMedia entity)
at Umbraco.Core.Cache.DefaultRepositoryCachePolicy`2.CreateOrUpdate(TEntity entity, Action`1 persistMethod)
at Umbraco.Core.Persistence.Repositories.RepositoryBase`2.PersistUpdatedItem(IEntity entity)
at Umbraco.Core.Persistence.UnitOfWork.PetaPocoUnitOfWork.Commit(Action`1 transactionCompleting)
at Umbraco.Core.Persistence.UnitOfWork.PetaPocoUnitOfWork.Commit()
at Umbraco.Core.Services.MediaService.Umbraco.Core.Services.IMediaServiceOperations.MoveToRecycleBin(IMedia media, Int32 userId)
at Umbraco.Web.Editors.MediaController.DeleteById(Int32 id)
at lambda_method(Closure , Object , Object[] )
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass10.<GetExecutor>b__9(Object instance, Object[] methodParameters)
at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.Execute(Object instance, Object[] arguments)
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__0.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext()
at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__2.MoveNext()
at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext()
at System.Web.Http.Dispatcher.HttpControllerDispatcher.<SendAsync>d__1.MoveNext()
I tried to change the database image paths on cmsPropertyData to the blob url but the error persists. The images on website looks good but on BO i can't do anything with it. I added new ones at it works fine but with the old ones I have this issue and I need to update it. Also if I delete some of the images attached i get this
and the same back-office error. Any help would be appreciated.
cmsPropertyDatato the blob url but the error persists. The images on website looks good but on BO i can't do anything with it. I added new ones at it works fine but with the old ones I have this issue and I need to update it. Also if I delete some of the images attached i get thisand the same back-office error. Any help would be appreciated.
stack overflow issue here.
Hey Arlan,
Have you taken a look at the cmsContentXML table?
I would check to make sure its pointed to the correct blob instance.
Hi Joe, in this case the path on the db are relative (as on the image)
/media/1031/jam-800x600.jpgThe other issue is that throws this error and on logs I have this
I follow the next steps to get my site on again:
I upgrade my site to Umbraco 7.5.14 and reset all the configs.
Then I configure all the settings using this configs following this recommendations
My site are now OK
Thank you all for your patience.
