  • Tim Watts 90 posts 395 karma points
    Nov 02, 2017 @ 10:19
    Tim Watts
    Hi Nathan,
    Umbraco currently has a minimum SQL version of 2008. Plumber is using the OFFSET/FETCH in the ORDER BY clause which is SQL2012 and later.
    It should be somewhere in the documentation that Plumber has a higher requirement than Umbraco itself. Might have saved me a few minutes of looking at the source code!
    I'm getting a lot of errors at the moment, hopefully they'll go away once I've migrated the DB.
    Regards,
    Tim
    Nov 02, 2017 @ 10:56
    Tim Watts
    I'm now on SQL 2012 and investigating Plumber properly. As expected, my initial errors have gone away.
    Tim
  • Nathan Woulfe 445 posts 1662 karma points MVP 5x hq c-trib
    Nov 12, 2017 @ 01:05
    Nathan Woulfe
    Hi Tim
    Sorry for the slow reply - my host broke my email, and neglected to tell me, so missed the notifications for your posts.
    I'd like to keep SQL requirements inline with Umbraco, so will review this.
    EDIT: Have resolved this, will have a patch release out soon, hopefully with your other issues addressed as well.
