Clearer 'current flow' removal on node workflow in content tree
Hi Nathan,
In version 0.2.0.84, if you look at the workflow on a particular node on the content tree, clicking on anything listed under 'current flow' deletes it. For example:
if you clicked on 'News Story Review' in the screenshot above for that node's workflow, it would remove that flow option.
Our stakeholders found that confusing. Could this functionality be made more prominent to the user? Perhaps a big red x at the end, or a clickable word saying delete at the end, or something?
Thank you! (and again, apologies if this has already been fixed)
That's on the list of improvements at the moment - I'm adding drag and drop to allow sorting on the items, and clearer controls for deleting (similar to how Umbraco manages nested content etc).
Hoping to have v0.70 / v1 out soon. Started to revisit some of the architecture decisions, so have made some fairly large changes to how it's all put together.
Really recommend too moving onto the latest version (provided your Umbraco version is compatible) as there are a heap of new features and bug fixes.
OK, brilliant - thank you! Entirely my fault for not having kept an eye on the page to see there were updates :)
We were using Umbraco 7.7.4 but we've just upgraded to 7.7.9 - so hopefully we're still compatible...! :)
Thanks very much!
Hi Nathan,
Hi Nicola
N
OK, brilliant - thank you! Entirely my fault for not having kept an eye on the page to see there were updates :) We were using Umbraco 7.7.4 but we've just upgraded to 7.7.9 - so hopefully we're still compatible...! :) Thanks very much!
Absolutely compatible - I dropped supported for versions older than 7.7.0 as they are missing some key bits and pieces (mainly the groups UI stuff).
Well worth upgrading!
