  • Julien Kulker 75 posts 427 karma points c-trib
    Apr 06, 2018 @ 11:57
    Julien Kulker
    Plumber conflicts with Umbraco Forms: 7.0.0
    So i have found a issue with using plumber and Umbraco Forms 7.0
    First the specs:
    Plumber: Latest version Umbraco: 7.10.1 Umbraco Forms: 7.0.0
    When configure the workflow of the Umbraco Form the following angular exception is trowed!
    TypeError: mainTreeEventHandler.syncTree is not a function
    at Object.syncTree (umbraco.services.js?cdv=1329554360:5238)
    at umbraco.controllers.js?cdv=1329554360:8866
    at angular.min.js?cdv=1329554360:108
    at e (angular.min.js?cdv=1329554360:31)
    at angular.min.js?cdv=1329554360:34
    (anonymous) @ angular.min.js?cdv=1329554360:63
    angular.min.js?cdv=1329554360:63 TypeError:
    workflowResource.getAllWorkflowTypesWithSettings is not a function
    at init (umbraco.forms.js?cdv=1329554360:2903)
    at c.WorkflowTypesOverlayController (umbraco.forms.js?
    cdv=1329554360:2977)
    at d (angular.min.js?cdv=1329554360:28)
    at Object.instantiate (angular.min.js?cdv=1329554360:28)
    at angular.min.js?cdv=1329554360:53
    at angular.min.js?cdv=1329554360:44
    at n (angular.min.js?cdv=1329554360:7)
    at k (angular.min.js?cdv=1329554360:44)
    at e (angular.min.js?cdv=1329554360:40)
    at angular.min.js?cdv=1329554360:39
    Removing the plumber plugin makes Umbraco Forms work again. But that isn't really a possibility.
    Hope you guys can help me out
  • Alicia Butler 10 posts 101 karma points
    May 02, 2018 @ 14:17
    Alicia Butler
    Install the latest version of Plumber (v0.7.8) and it will fix the issue conflicting with Umbraco Forms v7
