Plumber Content Buttons not changing based on permissions
I am using the latest (.7.7-Beta) version of plumber, and i am not sure if I've misunderstood something or configured it wrong. but the selection of options provided to a user in my workflow group is the same as someone who isn't in any groups.
All users see the buttons like below:
but I thought my non-admin users would have their Save and Publish Permissions removed ?
Is that right or have I missed something ?
My site the top level node has a one stage workflow with a 'site admins' group set as approval. and in the settings I have 'site admins' as default group and the flow set to implicit.
Looking at this locally, I'm seeing the correct set of buttons based on the user permissions - caveat there though is that any user with access to the workflow section is treated as an administrator and will have the save and publish option in the sub-buttons.
I've confirmed that with both a user in a workflow group, and a user not in any groups, both of whom do not have access to the workflow section
Can you check the user access to the workflow section? That's the most likely cause.
I might need to review the admin permissions, and simply use the Umbraco defaults rather than having a separate administrator context just for workflow. That would help too in that users could then have access to the workflow section, without that altering their publishing permissions...
The admin one is correct - if it's a node with a configured workflow, the default action is to submit into that workflow.
Will have another look at the non-admin. I'm sure it was working correctly locally, but I've got some other changes in the pipeline so will confirm it works correctly with those in place.
Changes will remove the requirement for setting a group on the root node, and the need to set a default group. I'd been working on the assumption that the workflow model would be applied to the entire content tree, but there are time when it might only be required on part, so having to set anything on the root is redundant.
Save and PublishPermissions removed ?Is that right or have I missed something ?
Kevin
Hi Kevin
Sorry for letting this hang, but I've had time to revisit this now:
Just installed a fresh version of Plumber (0.7.8-rc) against the umbraco version you have in the repo (Umbraco 7.9.2).
Fresh Install / standard starter kit:
I have done the following:
Create a new umbraco user (Lesser User) just put them in the umbraco editor group - no workflow group
Login with the lesser user : they can't see the workflow section :
but they see these buttons :
Shouldn't the save and publish button be removed ??
(which is the same - but that's a screenshot of the admin account honest)
Shouldn't the Admin Account have normal "save and publish" buttons ?
Again, have i understood it correctly or am i missing a step somewhere?
K
Hi Kevin
Yup, that's a bug. Non-admin user is getting the full button set - should be seeing the request publish and save buttons only.
And just realised I'd fix this (pretty sure) but hadn't updated the project - have done so now, 0.7.8-rc-000202 is the latest version
That includes the other changes I mentioned above, so the default group now does nothing and will be removed in future.
Hopefully that's sorted it...
N
