  • Kevin Jump 2348 posts 14896 karma points MVP 8x c-trib
    Dec 03, 2018 @ 19:51
    Kevin Jump
    Rejected Content stuck in workflow
    I've got a peice of content that has been rejected in workflow, but now when you go to it, you get Document is in workflow, and you can't seem to get it out
    Suspect i am missing a step somewhere ?
  • Nathan Woulfe 447 posts 1665 karma points MVP 5x hq c-trib
    Dec 03, 2018 @ 20:06
    Nathan Woulfe
    Hi Kevin
    First thing I'd check is that the user has permission to action the workflow - if they do, there's definitely something wrong...
    Any JavaScript errors in the console?
    What version are you running? There were some issues with the button stated not syncing correctly in an older release.
    Dec 03, 2018 @ 20:17
    Kevin Jump
    yeah its the main site admin, who is also in the worflow group created for the workflow "site admins" group -
    the config for the page shows the workflow :
    version 1.0.3
    No javascript errors on the page - but there is one on workflow dashboard.
       "ExceptionType":"NullReferenceException",
        "ExceptionMessage":"Could not get log dates","StackTrace":"   at Workflow.Api.LogsController.GetDateList()"
    if its not obvious i might just dive into the code/db and see what i can find.
    Dec 03, 2018 @ 20:23
    Nathan Woulfe
    That log error has been on my to-fix list for a while - it's an error thrown when there are no errors in the log, which in turn adds an error to the logs, and effectively fixes itself...
    I'll have a look into this one too, was certain it was fixed, but it's probably related to the workflow only being a single step - there's noone to reject the change back to (or the code assumes a group, not the original editor)
    Dec 06, 2018 @ 07:30
    Nathan Woulfe
    Hi Kevin
    Had a chance to dig around a bit, I think this is working correctly, if not clearly.
    I've done the following to reproduce:
    • set a single group as the inherited approval group on the home node
    • edited a piece of content, as a user NOT in that approval group
    • submitted for approval
    • switched to the approving group
    • rejected content
    When I log back in as the original editor, I can edit the content and resubmit for approval. If I log back in as a member of the approving group (prior to having resubmitted), I can cancel from the dashboard, but not from the node itself).
    I think what should be happening is that admin-type users should always have full access to circumvent workflow (ie should have the complete set of options in the editor drawer menu, regardless of the content state).
    Can you confirm for me that the dashboard gives the option to cancel? I'll get an update out with the admin permissions fixed too.
    Dec 06, 2018 @ 07:48
    Nathan Woulfe
    2
    And a bit more digging - I had a misnamed variable (adminUser vs isAdmin) so the condition for displaying the cancel button was never true for rejected content, so never displayed.
    Will patch and push.
    Dec 06, 2018 @ 09:45
    Kevin Jump
    woot !
    you rock, thanks again .
