  • Fiona Garnet-Lawson 26 posts 137 karma points
    Feb 13, 2019 @ 10:20
    Fiona Garnet-Lawson
    Hi - can anyone confirm by direct experience that Plumber v 1.1.4 is compatible with Umbraco v 7.13.2? (as the package compatibility report section on the website hasn't been updated...)
    Also, it is possible to upgrade Plumber incrementally from early versions eg: v 0.7.5 to a release version ie: v 1.1.4?
    Or does it have to be uninstalled, and then the latest version reinstalled?
    thanks D
  • Nathan Woulfe 445 posts 1662 karma points MVP 5x hq c-trib
    Feb 13, 2019 @ 10:36
    Nathan Woulfe
    Hi Fiona
    I haven't used it extensively on 7.13.4, but it is certainly compatible - if you're on an older Plumber version, that's more likely to have issues than the latest build (7.1.5 as of this morning)
    The indicators on the package page (for all packages) aren't a great indicator as they depend on other users providing the feedback.
    You should be fine to install over the top of your current version, straight to the latest release. I handle some database changes internally, they'll all run in order when you install.
    As always though, run through an update in a non production environment first, just in case!
    Feb 13, 2019 @ 10:38
    Fiona Garnet-Lawson
    Thanks Nathan - and so fast too!
    Fiona
    Feb 13, 2019 @ 10:48
    Nathan Woulfe
    No worries! Happy to help
  • Marc-André 63 posts 279 karma points
    May 13, 2019 @ 19:55
    Marc-André
    Is plumber schedule to work on v8 anytime soon?
    May 13, 2019 @ 20:12
    Nathan Woulfe
    Yes. Working on essentially a complete backoffice rebuild, and substantial changes to the rest of the package.
    No expected release date yet, but won't be too far away.
    May 13, 2019 @ 20:13
    Marc-André
    All right! Thanks Nathan! Looking forward to it! :)
  • Giampiero D'Agostino 14 posts 106 karma points
    Aug 12, 2019 @ 04:19
    Hello, I was wondering if there's a timeline for Umbraco 8 compatibility. I'm about to develop something that might be built around this plugin and it's just to evaluate if it's better starting this with Umbraco 7 or 8. Cheers, Giampiero
    Aug 12, 2019 @ 04:38
    Nathan Woulfe
    Hi Giampiero, I'm hoping to have a beta out in a couple of weeks - it's feature-complete (for now), just needs testing.
    Fairly substantial changes to how it all works, but still fundamentally does the same stuff.
    I'll post updates to Twitter if you're interested (@nathanwoulfe)
  • Ettienne 4 posts 84 karma points
    Aug 20, 2019 @ 22:58
    Ettienne
    I am in a similar situation that I have a project that is close to kick off, Workflow is a hard requirement so it very much influences whether or not we choose Umbraco 7 or 8.
    @Nathan please let us know if there is anything we can do to help test the beta.
  • Jose Marcenaro 10 posts 111 karma points c-trib
    Sep 26, 2019 @ 12:56
    Jose Marcenaro
    Hi Nathan, it's great to know you are working on a beta for v8.
    Are there any beta or alpha bits we can start testing already? Thanks!
    Sep 27, 2019 @ 01:25
    Nathan Woulfe
    Absolutely - https://github.com/nathanwoulfe/Plumber-2/releases/tag/v1.0.0-beta
    I'll add new releases every so often until I'm out of beta. The core workflow component hasn't changed from 7 to 8, since that doesn't touch on Umbraco at all. It's everything that interacts with it that has been changed!
    Things have taken a bit longer than I'd hoped, have to prioritise paid work, but the beta is pretty solid. Should also be possible to upgrade from 7 to 8 without any pain.
    Nov 21, 2019 @ 01:28
    Nathan Woulfe
    v8 compatible version is on nuget now - Plumber.Workflow.
    Requires 8.3 minimum.
