Recycle bin - duplicate "Save and publish" button groups, rather than expected ones
I have an install of Workflow 1.1.5 on Umbraco 7.13.2, and the content items in the recycle bin show two copies of the "Save and publish" button, rather than the expected "Preview" and "Restore" ones.
Is anybody else seeing this? I imagine the recycle bin is probably the last thing that gets tested!
If Alex is right (which let's be honest, he probably is!) then this my favourite type of issue - someone else's fault!
I'll double check though that it's not something I'm doing causing it as well.
EDIT: might be fixed in 7.14, but will still be an issue in Plumber as I replace the footer buttons. I'm due a patch release tomorrow, will include this.
It may though break older versions as the default Umbraco buttons are different, but will see what happens - might mean that older Umbraco installs stay on older Plumber versions.
Thanks Dave
Hi Dave
This issue has been fixed already, in version 7.14 right buttons are in place for nodes in Recycle bin. So just upgrade Umbraco :)
Alex
Thank you both!
All sorted - v1.1.8 will be on nuget shortly (and on the package repo in a minute or two). Buttons on trashed content should now be ok back to v7.8.0
