Did you find a solution to this Mike? I have run into the same problem.
Umbraco.Web.Trees.ApplicationTreeExtensions.TryLoadFromControllerTree(ApplicationTree appTree, String id, FormDataCollection formCollection, HttpControllerContext controllerContext)
at Umbraco.Web.Trees.ApplicationTreeController.<GetRootForSingleAppTree>d__2.MoveNext()
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at Umbraco.Web.Trees.ApplicationTreeController.<GetApplicationTrees>d__0.MoveNext()
at System.Threading.Tasks.TaskHelpersExtensions.<CastToObject>d__3`1.MoveNext()
at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__0.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext()
at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext()
at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__2.MoveNext()
at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext()
at System.Web.Http.Controllers.ExceptionFilterResult.<ExecuteAsync>d__0.MoveNext()
at System.Web.Http.Dispatcher.HttpControllerDispatcher.<SendAsync>d__1.MoveNext()
ApplicationTreeController Error
I'm getting an error in the right sidebar saying:
Umbraco version 7.12.2 Plumber 1.1.6
It basically errors out and doesn't create the options in the left sidebar to configure the approval groups
Any help would be greatly appreciated!
Hi Mike
Unfortunately I can't reproduce this - no Tree errors when I'm running locally, on a fresh 7.12.2 + 1.1.6 installation.
First thing I'd recommend though is bumping up to the latest version (1.1.8), but nothing changed from .6 to .8 that would impact on that error.
Is there anything more detailed in your site logs?
Are you using IOC library in your project?
Looks like you are using IOC, you should register all controllers and api controllers via IOC
