  • Angad Bhat 22 posts 42 karma points
    Oct 19, 2010 @ 12:10
    Angad Bhat
    Courier not picking data
    I am using this data type in my website. I am also using courier to transfer content from staging to live. when I transfer data from staging to live all the data is transfer but the data that is in the "related links with media data" type. Any setting I need to do/change for this to work?
    Thanks in advance.
    Regards,
    Angad
  • Marco Lusini 176 posts 1370 karma points
    Oct 19, 2010 @ 14:08
    Marco Lusini
    Uhhmmm.... I never used Courier, so I couldn't test with it.
    AW, Related Links with Media should behave just like the standard Related Links data type, have you checked if it has the same misbehaviour?
    /Marco
    Oct 19, 2010 @ 15:10
    Angad Bhat
    Hi Marco,
    Thanks for your reply. I checked the standards related links data type and courier seems to transfer the data from staging to live but not for the related links with media data type. There is a config file for courier to specify the ids for content types and data types(custom) but I don't know what to enter regarding the "related links with media" data type. (something like this http://forum.umbraco.org/yaf_postst8890_Does-Courier-support-Lefteris-Multiple-Pickers.aspx)
    Any help would be appreciated.
    Thanks.
    Angad
    Oct 19, 2010 @ 15:15
    Marco Lusini
    The GUID of Related Links with Media should be this:
    4848424b-ec2c-45f7-a9aa-712bc703b75e
    Hope this helps...
    /Marco
    Oct 19, 2010 @ 15:36
    Angad Bhat
    Marco,
    I added this line under contentpickerdatatypes and mediapickerdatatypes element in the courier config file but no luck
     <dataType alias="relatedLinkWithMedia">4848424B-EC2C-45F7-A9AA-712BC703B75E</dataType>
    Is there anything else I need to do?
    Thanks in advace.
    Regards,
    Angad
    Oct 19, 2010 @ 15:59
    Marco Lusini
    I'm sorry but I can't help you here, maybe you could ask the question with Courier support?
    /Marco
    Oct 19, 2010 @ 17:03
    Angad Bhat
    Marco,
    I found the answer here (our.umbraco.org/.../11151-Courier-and-related-links) . You need to add this line
    <dataType alias="relatedLinks" xPath="/links/*/@link">4848424b-ec2c-45f7-a9aa-712bc703b75e</dataType>
    under contentPickerDataTypes and mediaPickerDataTypes
    Thanks for your help!
    Oct 19, 2010 @ 17:09
    Marco Lusini
    Nice finding!
    Bye,
    /Marco
