  • Graeme W 113 posts 289 karma points
    Apr 24, 2014 @ 13:19
    Graeme W
    Will this work with version 6 ? ....
    ... has anyone used this in v 6 running in MVC mode ?
    Apr 24, 2014 @ 14:03
    Hi Graeme
    I don't think it will work but I have not tried to see if it works. But it should be a fairly quick task to setup a vanilla installation of version 6 and see what happens when the package is installed. But a lot has happened since 2009 where the package was uploaded.
    But I'm thinking...isn't there a related links datatype that comes with Umbraco out of the box? It's not necessarily setup by default but it should be possible to create it. If I recall correctly it should work in the same manner.
    Hope this helps.
    Apr 24, 2014 @ 14:24
    Graeme W
    Hi Jan
    Thanks for your response. There is a related links data type but it doesn't cater for media items. I presumed this package was to plug that gap.
    Graeme
