  • Jeavon Leopold 3074 posts 13632 karma points MVP 11x admin c-trib
    Apr 12, 2012 @ 10:48
    Jeavon Leopold
    Small bug if docTypeAlias is not set
    If you don't set the docTypeAlias attribute as you want to sort all document types but there is another document type within the folder being sorted that doesn't contain the sort field then you get a YSOD.
    Apr 12, 2012 @ 11:39
    Lee Kelleher
    Hi Jeavon, Matt is away this week, but I know he's generally up to his eyeballs in v5 dev.  Would you consider a fork 'n' patch?
    http://documentsorter.codeplex.com/SourceControl/network
    Would be great to have more community involvement! :-)
    Thanks, Lee.
    Apr 18, 2012 @ 15:09
    Jeavon Leopold
    Hi Lee,
    I will look into it and see if we can fix it.
    Thanks, Jeavon
    Aug 22, 2013 @ 14:52
    Jeavon Leopold
    Having completely forgotten I ever wrote this, I have already fixed the issue in v2.0.2 beta :-)
