  • Christian Bech 20 posts 51 karma points
    Feb 20, 2020 @ 20:04
    Christian Bech
    Bulma Starter Kit - DLL is not a valid mode
    I'm running a fresh install of Umbraco 8.5.3 and when I change the ModelMode in Webconfig to DLL I get this error:
    ModelsMode "DLL" is not a valid mode. Note that modes are case-sensitive. Possible values are: Nothing, PureLive, AppData, LiveAppData, Dll, LiveDll
    Is it possible to use the Bulma starter kit in any of the other ModelsMode modes?
    Best Regards
    Christian
  • Malthe Petersen 68 posts 383 karma points c-trib
    Feb 20, 2020 @ 20:07
    Malthe Petersen
    101
    Hi Christian.
    Have you tried with lowercase l: Dll?
    Regards Malthe
    Feb 20, 2020 @ 20:13
    Christian Bech
    Damn... this is embarrassing :-) I was so sure that the problem had something to do with the new build-in modelsbuilder in Umbraco that I did'nt see my own typo. Thanks Malthe ;-)
    Feb 20, 2020 @ 20:25
    Malthe Petersen
    No problem, happy to help. Those errors happens to all of us every single day :-)
  • Matt Barlow | jacker.io 164 posts 740 karma points c-trib
    Feb 20, 2020 @ 21:02
    Thanks guys, glad that got sorted out quickly.
    Feb 20, 2020 @ 21:08
    Christian Bech
    Yes it only took two minutes before I was pointed in the right direction by Malthe .... Love this community and really fond of this starter kit
  • Biagio Paruolo 1621 posts 1914 karma points c-trib
    Mar 28, 2020 @ 18:04
    Biagio Paruolo
    In the Umbraco 8.5.4 is not supported Dll. The supported model builders are:
    Mar 28, 2020 @ 21:54
    Christian Bech
    Thats right Biagio. You still need to include the Modelsbuilder to your solution for this package to work.
    Mar 29, 2020 @ 18:51
    Biagio Paruolo
    So I’ve to create a Visual Studio project and compiling the project with class in AppData or install the full models builder https://www.nuget.org/packages/Umbraco.ModelsBuilder/ ?
    Mar 29, 2020 @ 19:20
    Christian Bech
    I installed the full models builder using nuget.
    Mar 29, 2020 @ 19:53
    Biagio Paruolo
    Ok. So is possible to use and install the starter kit under Visual Studio and after move on the server.
    Mar 29, 2020 @ 20:07
    Christian Bech
    Thats the way I do it ;-)
