  • sam 6 posts 76 karma points
    Jun 21, 2019 @ 08:33
    sam
    Bulma
    This looks great as it is compatible with V8 can i ask how would I add a slider and what one would I add - complete beginner here... thank you Sam
  • Matt Barlow | jacker.io 164 posts 740 karma points c-trib
    Jun 21, 2019 @ 12:45
    Firstly, thanks for using my Starter Kit!
    Bulma CSS is JS framework agnostic, it doesn't come with any bootstrap style JS components.
    Therefore you can add any slider that you wish. I recommend Glide Js
    A tutorial for that is beyond the scope of what I can write here, but basically you do the following:
    1. Create your doctypes for the slider
    2. Use models builder to create your models from the doc types.
    3. Create a razor view and add your html for the slider, hook this up to the model.
    4. Add your library and JS files to your master template.
    Without step-by-step instructions this probably is beyond the scope of a beginner, but it doesn't take long to learn once you get started.
    I will create some tutorials at some point, but lacking time at the minute.
